Question about threaded rods and ASTM specifications?
You can call for an all-thread or threaded rod in different material grades. Two examples would be A36 and A307. However, do each of these ASTM specs cover the formation of threads on these rods. Or is there another spec that universally covers formation of the threads for all threaded rods?
RE: Question about threaded rods and ASTM specifications?
So, if I want an A36 threaded rod, I should reference ASME B1.1 for the threads and that will be adequate for drill-and-epoxy applications?
