Dimensioning Problem
I have a slight problem using dimension function for this
item. I need to place a dimension parallel to the part and thru the radii centers. I have attached a pic to illustrate. Again, I will need a dimension from top center of radius to bottom center of radius, but not vertical , but parallel to long slightly angled portion.
Thanks much.
RE: Dimensioning Problem
Create a construction line thru one point, perpendicular to the side of the part. Dimension from the other center to this line.
Hardie "Crashj" Johnson
SW 2011 SP 4.0
HP Pavillion Elite HPE
W7 Pro, Nvidia Quaddro FX580
If you dimension between the two sketch points, you can RMB>>Align with edge, after you place the dimension.
Joe
SW Premium 2011 SP0.0
Dell T3500 Xeon W3505 2.4Ghz
6.0GB  Win7 Pro x64
ATI FirePro V5800
