Can I do this with a chamfer?
Please see the attached image. I made an extrude cut of a triangle on a diagonal of the cube. Can I make the same geometry with a chamfer or some other way that doesn't involve creating a new plane?
RE: Can I do this with a chamfer?
Yes, just pick the corner node and apply your chamfer.
"Art without engineering is dreaming; Engineering without art is calculating."
Have you read FAQ731-376: Eng-Tips.com Forum Policies to make the best use of these Forums?
I figured as much. I didn't realize you had to select the Vertex radio button. Thanks!
