Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...it was ingeniously designed and all those clicks were for my own good... and that was even before I got my speedy and useful answer to my tekkie question that I eventually posted..."
Geography
meca (Structural)
9 Nov 11 9:20
If a structure is flexible (NF < 1 Hz), then we must calculate the flexible gust factor.  If the structure has a stiffness which is significantly different in each direction,  do we still base the gust factor on the lowest natural frequency for the entire structure?  Or is the intent to determine the lowest frequency in the direction that is under consideration, and use that Frequency for the gust factor calculation?
For example, if a structure has a Frequency of 0.7 Hz when looking at a direction, and 0.35 hz in the perpendicular direction, do we still use 0.35 Hz for the basis of G used in for wind pressures in both directions?
WillisV (Structural)
9 Nov 11 9:55
Determine G independently for each direction based on the predominant mode in that direction.
Close Box
Join Eng-Tips® Today!
Join Us             Close
