Counting thermostats opening and closing
I've made a test rig that tests thermostats opening and closing.
I have fifteen stats on test. I'd like to count the switches opening and closing. Can I put a small DC voltage through the switches and measure this going from +V to 0 and counting the pulse.
Is there something on the market I could use? Nice and simple as I am a meterials engineer not a programming/hardware wizard!
RE: Counting thermostats opening and closing
A dry contact counter will count the simple opening and closing of a switch, no voltage involved.  Ideal for thermostat testing.  We use these on our cycle test rigs.  They are very reliable and won't introduce anomolies into other electrical equipment.
http://www.grainger.com/Grainger/REDINGTON-Counter-2PPW3?cm_sp=IO-_-IDP-_-RR_VTV70300505&cm_vc=IDPRRZ1
