find temp knowing the humidity ratio and enthalpy
hi
Problem: Have a dryer that is evaporating water off a product at a rate of 2923 lbs of water/hr. If we pull room air at 70F @ 50%RH at rate of 23738 lbs/hr.
 What is the temperature of the resulting air stream?what formulas do I use?
RE: find temp knowing the humidity ratio and enthalpy
If that's all you know about the process then you can't get there.
dry bulb temp of 70 with a 50% RH means your wet bulb temp is about 58.5 and  enthalpy is 25.33 btu/lb
if youre at 1000 cfm the temprature of the 2nd airstream would be 81 degrees F.
If this information was not at all useful to you or anybody else I apologize.
Without any kind of calculation - like 500degF or something?!
You are adding roughly 0.1 lb/lb, when your room air normally contains around 0.01 lb/lb.  If you have any hope of removing this much water with this much air, it will need to be jet wash from an F-18.
thanks for the feed back.
we are planing having a air stream of 5000cfm.
MattyWaste how did you calculate or find 81 F?
thanks again
Tom
SCIENCE!
