Changing Arrow Location on Detailed View
4
Hi Guys,
How do I change the location of where the arrow of the label points to on a detailed view.  In the attached picture, I would like it to be near the bottom of the circle, not the top.
Chris
NX 7.5
RE: Changing Arrow Location on Detailed View
Move the view label (Detail C) around until the arrow is normal to the centerpoint of the hole, then hold the shift key down while moving it so the arrow stays normal to the hole center.
One more thing . . . the arrow will snap into place when it is normal to the view center.
Select Detail boundry on drawing view / Hold Shift and select the arrow/leader/letter and move as desired.
Thanks for the quick response guys, worked like a charm.
