is there difference between a linear solenoid and a linear actuator?
I am designing a system that requires a pin to be pulled back to drop a ball in a tube. Based on my research I found a linear solenoid device and a linear actuator. Are they the same thing? If they are different, what are the key differences? I am looking for a low cost part that doesnt need to be precise. Just a small electric motor that pulls a pin in and out.
Thanks.
RE: is there difference between a linear solenoid and a linear actuator?
All linear solenoids are linear actuators.  Not all linear actuators are linear solenoids.
A linear actuator could be mechanically driven.
sunburn731,
   Most commercial solenoids are an electric coil, a magnet and a spring, rigged up somehow.  You turn them on and off.  Some solenoids are bi-directional.
   Something called a linear actuator should be more sophisticated than that.  Probably, it can move to a set of positions or a continum of positions, and tell you where it is sitting.
   The terminology should not really be important.  Which one does what you want?
   Remember, a regular solenoid consumes power while it is on.  All of that power is converted to heat.
               JHG
An electric solenoid has a defined travel and travels that amount every time it is activated.  An actuator can be commanded to a position anywhere within the range of its travel, and its ultimate number of positions could then be infinite.
rmw
I was taught rmw's answer.  I'll second it.  Solenoid, to me, means two-position.  Actuator is variable-position.
Good on ya,
Goober Dave
There are also latching solenoids which do not require power to maintain "open", rather a pulse of power to lock, and another pulse to unlock.
If you want to actually drive it with a motor per your statement.  Then you need an actuator.  I would search screw jack for pretty inexpensive version that a motor will attach to.
I think the OP was referring to a solenoid, technically it is a linear motor, and is ideal for the application that was referred to.
