Checking and the maintenance of the dissimilar check valves
Dear all,
Currently I am working on the project, where we installed two dissimilar check valves to protect system from the back flow. One of our concerns now is how to do a regular check of these valves without disconnecting them. I would appreciate if you could advice me a standard which I can use for this issue.
Thanks in advance.
Thanks in advance.
RE: Checking and the maintenance of the dissimilar check valves
