Frying Pan
Frying Pan
Frying Pan
Is this the same as a blank with flange pattern holes & a handle? One would put it between two flanges.
RE: Frying Pan
Search on paddle blind
RE: Frying Pan
Air, water, for testing in general.
Frying pan for the handle I think.
RE: Frying Pan
The problem with using colloquialisms and jargon without any context, instead of concise and unambiguous terms, is that quite often people have no idea what you are talking about.
RE: Frying Pan
something I cook eggs and bacon on!
How could you do anything so vicious? It was easy my dear, don't forget I spent two years as a building contractor. - Priscilla Presley & Ricardo Montalban
RE: Frying Pan
Something you jump out of, to land in a fire.
RE: Frying Pan
It could be used to create a pound of steam!
RE: Frying Pan
Thanks everyone the replies....colloquialisms can be a problem...I agree....
RE: Frying Pan
Quote (CorBlimeyLimey):
eh, you'll just end up with about a pound of condensate...
NX 7.5
Teamcenter 8
RE: Frying Pan
Quote:
Walterke (Industrial)
9 Nov 11 8:05
Quote (CorBlimeyLimey):It could be used to create a pound of steam! eh, you'll just end up with about a pound of condensate...
but do they weight the say?
RE: Frying Pan
depends on the amount of delirium
NX 7.5
Teamcenter 8
RE: Frying Pan
lmao @ steam
RE: Frying Pan
how do you determine the weight of steam, it must be weightless as my bathroom scales does not register anything when I boil water under it.
RE: Frying Pan
tinsmith04090,
   Where I work, somebody designed an electronic device they called a roach motel.  I hope this never got shipped to a customer.
   Perhaps the people where you are need a little more discipline when it comes to device naming.
               JHG
RE: Frying Pan
I thought a roach motel was a holy refrigerator.
Mike McCann
MMC Engineering
RE: Frying Pan
Why would you assume I named it anything drawoh
RE: Frying Pan
Quote (toughshibits):
   I'm not.
   A frying pan is what I use to cook bacon and eggs.  I have never seen a frying panel with flange pattern holes, and I cannot imagine bolting it to the stove.
   A very long time ago, I complained to an engineer about sloppy terminology, and he told me about searching through a plant for a resin dewaterer.  All he got was blank stares when he asked about it.  It turned out everyone called it a bird bath.
   You are describing something called, by someone, a frying pan, that appears to be something else.  Actually, if it was you who named it a frying pan, you would know what it really was, and you would not have posted.
   Sometimes, you need to develop the habit of staring blankly and stupidly at people when they use silly nicknames for stuff that you and your co-workers need to understand.
               JHG
RE: Frying Pan
A paddle blind wouldn't even make a very good frying pan.  No lip to contain the drippings.
RE: Frying Pan
Frying Pan & Paddle Blind are the same.....thanks to some that paid attention.
RE: Frying Pan
Actually, I think people were gently pointing out that a paddle blind and a frying pan MAY be the same thing, or sometimes they may not.
"I love deadlines. I love the whooshing noise they make as they go past." Douglas Adams
RE: Frying Pan
A flat or "lipless" frying pan is a comal, used for heating up tortillas.
"Gorgeous hair is the best revenge."  Ivana Trump
RE: Frying Pan
casseopeia,
   Comal is also a structured language developed at Waterloo University for eight bit Commodore computers.  I have a book at home somewhere on it.
               JHG
RE: Frying Pan
Absolutely right Cass!  So a lipless frying pan would serve some purpose after all. And lefse and knekkebrod, me being Norwegian, that one also did not dawn on me until right this moment, although lefse is best done on a big flat-top.
RE: Frying Pan
One man's frying pan is another's spectacle plate?
JMW
www.ViscoAnalyser.com
RE: Frying Pan
A lipless frying pan is a griddle
RE: Frying Pan
Well I'd guess at its being an unfinished orifice plate or a blanking plate.
These are sometimes used as to stop flow or are supplied blank for the orifice to be machined later.
This one is drilled and locates within the bolt circle.
Line spade and spacer?
Here is a blank without the bolt circle:
These are drilled and include the bolt circle:
JMW
RE: Frying Pan
This is making me really hungry.  As long as we are talking frying pans and colanders, can we talk pork chops?
RE: Frying Pan
I have heard them called blind flanges
when the hole is drilled for flow measurement
it is then it becomes a spectacle flange.
Hydrae
