NX6 Point Constructor Deformable Follow
Hello
I'm trying to make a deformable spring with 3 Helix , the first Helix is Fix, the second  is the one that I made deformable or variable I only increase the Pitch and this change the length but I have a problem to fix the third Helix to the end of the second
I tried to put a Formula but this give the result , when I change the pitch this stay at the same position in Z
I attach some pictures if I do not explain correctly
