Loose Anchor Bolts
Loose Anchor Bolts
I have some loose anchor bolts on an old concrete corbel (bracket). The bracket supports a roof truss.
The anchors appear to be regular bolts that were cast in place with the bolt head obviously in the concrete.
The bolts appear to have worked loose as there is some gap between the nut and plies of the truss.
I have been trying to think of a fix for the condition, but there is really no way to remove the old bolts.
Ideas?
Ideas?
RE: Loose Anchor Bolts
http://www.FerrellEngineering.com
I can't beleive the anchors even came loose unless the original installation was piss-poor.
you maybe onto something there
Unfortunately, I moved on so I can't say if it worked.
I agree that epoxy on dust wont "glue" it in position, but it could lock it in place mechanically.
Michael.
Timing has a lot to do with the outcome of a rain dance.
