Amada splining
Amada splining
Hi guys,
I have an issue when cutting splinees & i hope someone with an Amada has resolved this issue and willing to help out.
Control is Fanuc 160i-L
When cutting of splines or contours with lots of directional changes the axis stops (almost) at every line before starting the next line (this of course is happeing very quickly but it can be seen by the head shuddering when cutting a spline).
It's a real pain when cutting above 2000mm a min as it promotes burrs & limits the cutting feedrate to much less than commanded.
I have tried the G05 look ahead but doesn't make a difference.
G08 is no go as the control doesn't come with a RISC board.
I have turned off the edge data.
The control in not in exact stop mode.
Any one seen this before?
Cheers
Cheers
RE: Amada splining
If you post your DXF file, I can try to smooth it out for you.
RE: Amada splining
Thanks for the offer, I have been filtering as well but the jerking still occurs at the directional changes.
I was hoping is just a parameter in the control, like a "within tolerance" paramater.
Does anyone know if the trumpfs, Bystronics have the same prob?
Cheers
RE: Amada splining
Chris Krug http://krugtech.com/
Maximum Up-time, Minimum BS
