Check Analysis Quality out of memory
When i have done a simulation, i press "Check Analysis Quality", but i run out of memory. Is there any setting that allows NX to use more RAM? My computer has 4GB RAM, but XP only uses 2.7GB.
When i press solve, i can go to "Solver Parameters" and under "Nastran command keywords" there is a button with "Solution montior memory". This is set to 400MB. Does this have anything to do with running out of memory?
thank yoU!
thank yoU!
RE: Check Analysis Quality out of memory
A 64-bit machine may sove your problem since the memory limitation is higher than you can stuff physical memory in the box.
Ben Loosli
NX 7.5
Teamcenter 8
Windows 64-bit is the only solution.
Ben Loosli
