common-base LNA
common-base LNA
I am investigating the schematic of a FM common-base amplifier. It has two diodes that I do not know what are they used for.
D4 are two BAV99 diodes in a SOT323 package. I think they are used as an ESD protection. Does anyone know why are connected in such a way?
Pin 4 of the transformer is the RF input signal.
RE: common-base LNA
Once the circuit is drawn "correctly" (<- my opinion), then the function of each component typically becomes obvious.
RE: common-base LNA
I have done the layout according with a common-base configuration.
It's more clear now and easy to understand. After checking I thought these diodes could work as a power supply reverse polarity protection for Q1, but C9 confused me.
Well, if you have any comment they will be wellcome.
RE: common-base LNA
Standby to see anyone else drops by the thread...
RE: common-base LNA
RE: common-base LNA
I have also removed D4 and the amplifier keeps amplifying, I think they are used as some kind of protection. Any ideas about what they are for?
