Welding compatability
Just wondering if anyone can help me out? I have a torque tube that has been cracked and weld repairs carried out using 232 gas-less welding wire, I have to weld the spherical bearing to the torque tube with FCAW E71T1 wire as per welding procedure. Just curious to know if welding over the top of the 232 gas-less wire will be a problem? For my mind it's not the done thing welding over 232 with flux core is not compatible. Would appreciate your input if anyone knows.
RE: Welding compatability
As a rule I don't let friends use gasless (self-shielded) FCAW wires.
