NX7.5 Dimension Setting
Please see attached JPG. What setting in NX7.5 will make the Circled dimension line in the attached JPG picture shorter? I have been all over the annotation preferences and could not find it. Thanks for the help.
RE: NX7.5 Dimension Setting
Go to...
Insert -> Symbol -> User Defined...
...and set the 'Use Symbols in:' option to 'Utility Directory' and select the 'ug_default.sbf' file. From the list of symbols, select either 'GAP125' or 'GAP25' and then follow the instructions on the Cue/Status Line. After selecting the Dimension and when placing the symbol select near the end of the arrow that you wish to shorten. You may have to try this a couple of time until you get it right.
John R. Baker, P.E.
Product 'Evangelist'
Product Engineering Software
Siemens PLM Software Inc.
Industry Sector
Cypress, CA
http://www.siemens.com/plm
UG/NX Museum: http://www.plmworld.org/p/cm/ld/fid=209
That's right and best procedure. But user don't need to repeat it to get the right result. After performing the operation suggested by John, User can go for move component to get exactly.
Procedure: NX Drafting--Edit--component--Move Component--select the broken line area and move to get exact.
Best Regards
