Over/Under dimension Limit tolerances
In Pro/E WF5 the limit tolerances showed in drawings as an over under limit. That is the high value on top of the low value. In Creo/Parametric the limit dimensions are now displaying as High-Low.
Is there a way to display them as it did before?
RE: Over/Under dimension Limit tolerances
Before clicking the check box in my dim properties box I had all linear dimensions showing as over/under but the radial ones were displaying with hyphens.
