NX7 - Invalid annontation specified in entry field error when I type <
Okay, attempting to do a 'quick exercise' in NX7 Drafting, where I just want to create a simple "cut 'n paste" list of attributes that may be in a file. To do it, I am attempting use the old <W@$...> string. However, I am getting a "Invalid annotation specificed in entry field." when I type < in the Text Input Field in the Note Command.
Humor me folks, the morning is young and it feels like it has been a couple of versions of NX since I tried this method - but... has a new feature been added to NX or have I just simply forgotten a step?
RE: NX7 - Invalid annontation specified in entry field error when I type <
I really don't know of any situation, in NX, where they stopped supporting something in a newer version that was available in any previous version, and I have worked on it for over 20 years.
If you want the "less than" sign to be shown the use "<<"
The less than / greater than symbols are used for control characters so you can do things such as change the font or character size. Do a search for control characters within the NX help. You will see a list of them.
Not sure in the NX 7.5/8 but in some previous versions you needed to change it to blockfont to get some symbols to come in....(don't quote me on that but I want to say you had to for the copy right symbol) if that is the case you can type your text and use the font control <fn> and set the n to the blockfont number value possibly 0 or 1...
Example:
Your text <f1> $> <f>
Anthony Galante
Technical Resource Coordinator
NX4.0.4MP10, NX5.0.0->5.0.6, NX6.0.0->NX6.0.5, NX7.0.0->NX7.0.1 & NX7.5.0.32-> NX7.5.4.4, Beta NX8.0.0.25
I think there is some error in format. Cog' I have tested this in NX 8.0. It works Fine. Please follow the below format to get the result.
Drawing Sheet Attributes <W@$ attr_title>
<W@$SH_SHEET_NUMBER> Sheet number of the current sheet
<W@$SH_NUMBER_OF_SHEETS> Number of sheets in the current part
<W@$SH_SHEET_SCALE_NUMERATOR> Numerator of the sheet scale
<W@$SH_SHEET_SCALE_DENOMINATOR> Denominator of the sheet scale
<W@$SH_SHEET_SIZE> Size of the current sheet
<W@$SH_SHEET_UNITS> Units of the current sheet
<W@$SH_SHEET_PROJECTION_ANGLE> Projection angle symbol of the current sheet
<W@$SH_MASTER_PART_NAME> Master Model drawing sheet part name
<W@$SH_PART_NAME> Sheet part name
Best Regards
