Scale object in Pro/engineer ->drawing<-
I have a .part on this program. Imported it to a new Drawing, for A4 size.
But the object is too small on the sheet... Won't occupy a third of the availiable area.. it's hard to see, and a waste of space.
How do I scale the object inside the Drawing for it to look bigger without losing the measures?
(This is a copy of a thread I wrote up in the wrong place)
RE: Scale object in Pro/engineer ->drawing<-
Michael
To change the sheet scale, you can double-click the "SCALE: XXX" that's displayed at the bottom of the graphics area. You can also select "Edit" and "Value" and select that scale.
To change the view scale, double-click the view or select the view and "Edit" "Properties". There you can change Scale from 'Default' to 'Custom' and make it however large you would like.
Visit http://xsleuth.com and become a bonafide cybersleuth. Thanks, XSleuth (formerly telecomguy)
How did I not see that little number..
Huh... white on a little blue background... The guys are good on hiding stuff..
Thanx a lot, man..
I did not see your post in time..
Seems that you pointed the exhact thing too: The scale on the bottom of the sheet..
Thanx you too, man..
Happens to me all the time. You were more specific in your response though (*) I guessed what he was talking about because the Auto Scale is normally very small.
Michael
"It's not the size of the Forum that matters, It's the Quality of the Posts"
Michael Cole
Boston, MA
Follow me on ?w¡???
- @trajpar - @Shweep -
- ProE - SolidWorks -
My object was 400 mm; I had to put 0.75
This time, at least.
Their sizes alway vary; So the autoscale comes handy...
Not a problem to put the value manually everytime.
Decide the scale when propper to do so...
It's right here on the bottom... Just click it..
