Problem attaching XDB
Hi to everybody!
I've some problems with the xdb attachment of a model.This model is quite large, and the xdb dile is about 24mb.
When i perform attachment patran stops at ***Begin attach file***.
The statusi icon is green so probably patran is not working...
What's the problem? Could i attend some minutes? Memory is too small?
Any ideas?
Any ideas?
RE: Problem attaching XDB
CODE
$ translator on November 07, 2011 at 16:15:04.
$ Direct Text Input for Nastran System Cell Section
$ Direct Text Input for File Management Section
$ Direct Text Input for Executive Control
$ Linear Static Analysis, Database
SOL 101
CEND
$ Direct Text Input for Global Case Control Data
TITLE = MSC.Nastran job created on 07-Nov-11 at 09:00:46
ECHO = NONE
SUBCASE 1
$ Subcase name : Default
SUBTITLE=Default
SPC = 2
LOAD = 2
DISPLACEMENT(SORT1,REAL)=ALL
SPCFORCES(SORT1,REAL)=ALL
STRESS(SORT1,REAL,VONMISES,BILIN)=ALL
BEGIN BULK
$ Direct Text Input for Bulk Data
PARAM POST 0
PARAM PRTMAXIM YES
$ Elements and Element Properties for region : fasciame
PSHELL 1 1 6. 1 1
$ Pset: "fasciame" will be imported as: "pshell.1"
CQUAD8 24144 1 800516 800661 800599 800454 800578 800640
800557 800495 3.5
CQUAD8 24145 1 800661 800806 800744 800599 800723 800785
800702 800640 3.5
CQUAD8 24146 1 800806 800951 800889 800744 800868 800930
800847 800785 3.5
CQUAD8 24147 1 800951 801096 801034 800889 801013 801075
800992 800930 3.5
CQUAD8 24148 1 801096 801241 801179 801034 801158 801220
801137 801075 3.5
CQUAD8 24149 1 801241 801386 801324 801179 801303 801365
801282 801220 3.5
CQUAD8 24150 1 801386 801531 801469 801324 801448 801510
801427 801365 3.5
CQUAD8 24151 1 801531 801676 801614 801469 801593 801655
801572 801510 3.5
CQUAD8 24152 1 801676 801821 801759 801614 801738 801800
801717 801655 3.5
CQUAD8 24153 1 801821 801966 801904 801759 801883 801945
801862 801800 3.5
CQUAD8 24154 1 801966 802111 784301 801904 802028 802090
802007 801945 3.5
CQUAD8 24155 1 800454 953873 953927 800599 953872 953902
953932 800557 3.5
CQUAD8 24156 1 953873 953875 953924 953927 953874 953901
953925 953902 3.5
CQUAD8 24157 1 953875 953877 953920 953924 953876 953900
953921 953901 3.5
CQUAD8 24158 1 953877 953879 953917 953920 953878 953899
953919 953900 3.5
CQUAD8 24159 1 953879 953881 953915 953917 953880 953897
953916 953899
I am starting to wonder this may be a Boundary Condition issue. What sort of "FATAL" or "WARNING" messages in the .f06 file?
Sorry to bring up an old post but how did you end up solving the issue because I'm having the same problem.
Thanks in advance,
Dylan
