Which ground improvement technique to select
The foundation is a trapezoidal footing of 6 m length and widths of 6 m and 2 m with burial depth of 3.2 m. The subsoil is gravelly sand with about 7% fines. Measuring from the underside of foundation, soil is liquefiable between 2 and 3 m and again between 6 m and 13 m. Some loose sand may still be present below 15 m. Thank you for your response in advance.
RE: Which ground improvement technique to select
Mike McCann
MMC Engineering
Thank you for the feedback. We think the loose sand may extend beyond the 16.5 m that was investigated. Would you still do piling if the loose sand extends even more than 20 m.
Thank you for all the comments.
Mercycity - Here are the SPT data just beside the footing of 18 ft by 12 ft. Groundwater assume 1.5 m bgl and D = 3 m.
