ramp signal values, Gain values calculation for control simulation
How to calculate the ramp signal values and then when i am using First order low pass filter in a Position Sensor. The system is used to control the directional valve connected with a piston Cylinder. I am also interested in calculating K values of Gain.
I dont know how to do them. I know its a control problem. Please direct me...
Thanks.
The issue is I need to control the gain values and the ramp signal so that I can close the piston in different time durations, such as 2 sec, 5 sec and so on. And analyse the different pressures that come up in the hoses. Well I am unsure of how to achieve this. I need to know where to look for the solutions. To do more work where should i look into. I have read some books like, Hydraulic control Systems ed.2 but unfortunately I cant find how to optimize or how to even calculate the Ramp. I know I have to use the Low pass filter with 20ms time delay. Please give an idea.
Thanks.
Thanks.
Thanks.
RE: ramp signal values, Gain values calculation for control simulation
However driving with a ramp means that the valve will never close as it needs to constantly extend the cylinder in order to maintain balance.
What software is that simulation program.
Dan - Owner
http://www.Hi-TecDesigns.com
P.S MacGyverS2000 (Electrical) Yes last time I didnt find the right forum
http://e
You need to be able to work the algebra of the S plane to really devise a closed for expression for this.
G(s) will be the product of 4 terms
1 the first order lowpass filter
2 the gain K
3 the s domain description that relates the valve signal input to the pressure produced at the output of the valve.
4 another lowpass stage relating the pressure at the cylinder to the acceleration of the mass attached to the cylinder.
H(s) is relates the movement of the cylinder to the output of the position sensor.
Put all this together to make a probably second order system which the gain K can be selected to put the eigenvalues where they need to be for the speed of the response.
Its Hopsan Program. Download Location
http://www
I have made the equations but I need one thing to clarify
For the calculation of Kce (the servo valve's flowpressure coefficient) how do i find del qL (flow) / del pL (load pressure)
Are these across the servo valve?
qL = (qL1 + qL2)/2
pL = p1 − p2
And then, the system I have shown you in figure is it,Valve controlled SYMMETRIC cylinder with mass load or Valve controlled asymmetric cylinder with mass load, because then the Xp (Valve displ.) and hydraulic resonance frequency and damping is different. I use a double acting piston.
http://www
qL = (qL1 + qL2)/2
pL = p1 − p2
Can the formulas be used for 4 port directional valve as well?
As they are for 3 port valve. How can i calculate for 4 port valve.
I can't help you with the fluid properties of the valve as i am clueless about this.
If it's a specific valve maybe there is manufacturer information.
Or post in mech engineering forum to see if someone there can help.
Thanks for the link..
