ramp signal values, Gain values calculation for simulation.
How to calculate the ramp signal values and then when i am using First order low pass filter in a Position Sensor. The system is used to control the directional valve connected with a piston Cylinder. I am also interested in calculating K values of Gain.
I dont know how to do them. I know its a control problem. Please direct me...
Thanks.
Thanks.
RE: ramp signal values, Gain values calculation for simulation.
I like your approach not asking us to 'solve' your problem. But, since this is EngTips, I'm afraid you will have to do more work on your own before we can 'tip' you about the details. Good luck, though.
Gunnar Englund
www.gke.org
Thanks.
Gunnar Englund
www.gke.org
