Welding design in an Assembly - NX7.5
I need to make updates in a previously designed assembly.
Two of the components required welding design. The previous user created another component(the third one, a welding part) especially for that.
This file contains "Body" 3D geometry only. They are located at the welding area of the two components of the assembly.
My question is:
- Should the welding design be created as a component of the
assembly?
- Or as a 3D data geometry in the assembly file?
What's the best design practices for this topic?
My question is:
assembly?
RE: Welding design in an Assembly - NX7.5
Best Regards
BisRaNa
