Solidworks HUL setup
First let me say hello! New to the site but it looks very informative and excited to be a part of it.
Now to my question, I use Solidworks at work and I am going to start taking advantage of the HUL, but I have not found a good install guide.
My main question is when I install solidworks do I leave the port@server to the default that it shows for my home pc or do I put my work port@server in from my work SNL (solidnetwork license) so that I can borrow the license?
Jake
Jake
RE: Solidworks HUL setup
9000 leading number are HUL/stand alone
0010 leading are SNL serial numbers
Cheers,
Anna Wood
SW2011 SP4, Windows 7 x64
http://www.renderbay.com
http://www.solidmuse.com
http://www.phxswug.com
Cheers,
Anna Wood
So then when I install it at home solidworks asks for a port location does that matter? Or do I just install with default port location and then set up the VPN and share the license?
You need VPN access to your server at work to connect to the license server.
You can either stay connected to the VPN and the license server for your SolidWorks session. Or borrow a license for a certain timeframe and disconnect from the VPN.
You will need to talk to your IT people to arrange that.
Cheers,
Anna Wood
Dan
www.eltronresearch.com
Dan's Blog
0010 #### #### #### A1B2 C3D4
Require you to login to your server as Anna said.
If you have a laptop you can borrow a license from the server for upto 30 days and wouldn't have to login each day to get the license. For periods longer than 30 days SolidWorks can be borrowed for longer by special request of your VAR but very rarely happens.
Michael
I'd suggest using the HUL that Dan mentions above so call your VAR and see if you can get those special Serial Numbers for your company.
Dan
Dan's Blog
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
We have 6 seats of core SolidWorks and one seat of Premium SolidWorks under an SNL license. Our HUL licenses are for core SolidWorks.
If all your SNL seats are Premium seats then your HUL will be for SolidWorks Premium.
Cheers,
Anna Wood
