Things to Consider
Things to Consider
To all experts here I need an advice. this Idea comes in my mind after visiting out offshore field. At present we are burning a huge amount of gas to flare. Im thinking of ulitizing it for our online heater.. since we are using diesel power heater. I know it is posible but what factor I need to consider, our gas produced is zero H2S.. its basically a sweet gas.
RE: Things to Consider
The gas may not have H2S, but it might have other light hydrocarbons in it that would make it unsuitable. Your question really can't be answered until the actual compositon is known.
If it doesn't have any objectionable things in it, and you can capture it and control it, by all means use it if the cost of doing so justifies the capital cost and O&M costs of doing so.
rmw
And you are not adding to GW as some believe.
That was I wanted to do priding line heater using assciated gas or gas separated rather than burning it to flare. if you got some schematic I will highly appreciate it
