Taper port question
Taper port question
Taper port question
I know that it is common to use a taper external (male) thread with a parallel internal (female) thread for a hydraulic joint.
Is it possible to use the reverse, a parallel external (male) thread with a taper internal (female) thread.
More specific, would it be possible to create special taper tap so I can use a small standard 4mm metric set screw as a plug.
Thanks in advance
Nickjk
RE: Taper port question
It is not common to mix straight and tapered threads, in my experience.
Ted
Ted,
From: http://en.wikipedia.org/wiki/British_standard_pipe_thread
<<<<Jointing threads: These are pipe threads where pressure-tightness is made through the mating of two threads together. They always use a taper male thread, but can have either parallel or taper female threads. (In Europe, taper female pipe threads are not commonly used.)>>>>
From: http://www.ring-plug-thread-gages.com/ti-bs-21-ISO-7-Dry-Seal.htm
<<<<Now we are back to the use of the male external Rp parallel British Standard Pipe "Taper" (BSPT) screw thread with the female internal R tapered British Standard Pipe Taper (BSPT) screw thread to concentrate the pressure at one point and create a mashed together thread and a dry seal.>>>>
This is what I want to do but I have not found the parrallel male and taper female anywhere else during my research and not sure if it was an error.
Nickjk
Just use straight thread and epoxy the set screw in place.
Ted
I have seen a joint made up with BSP taper male into parallel female.  It took a lot of Loctite PST to stop it from leaking seawater at a few psi.  It may be common, but it's stupid.
Parallel male into taper female has less chance of working.
Use parallel/parallel and PST.
Mike Halloran
Pembroke Pines, FL, USA
Mike
I need to come up with a miniature way to plug an hydraulic passage.
The plug needs to be easily removable and fit inside a port.
The smallest 1/16 R is too large, need something around 4.5mm.
Mike I am quite surprised by your response. Just because you do not agree with something does not make it stupid.  This is not a method I have ever used but I am trying to keep an open mind to research found.
Nickjk
The particular joint I referenced, BSPT into BSPP, was on a boat that cost upward of 80 million USD.  The joint had already shaken loose from engine vibration.  I was not impressed.
Offended by 'stupid'?
Okay, it's lazy; saves a trip to the local Swagelok dealer to get a proper adapter.
The only US application of tapered male into straight female of which I'm aware is grease fittings with 1/4-28 threads.  Small hex plugs and grease nipples are available.
Not quite common in the US, but available and just a little bigger than 4.5mm, is 10-32 straight threads.  They're traditionally sealed with a flat gasket, but PST works better.  The common plug for this series looks like a cheese head screw, and is usually the diameter of a pan head.
As to your original idea of using a straight thread setscrew into a tapered thread hole, I wouldn't do that, because you're basically trying to make a seal against the end of a thread, where the shape is not specifically controlled.  I might be tempted to use a cone tip setscrew run into a straight thread hole with a countersink at the bottom, or maybe a flat bottom.  ... but I'd be more comfortable using  a headed screw and sealing on the flat face under that.
Above a couple hundred PSI, I wouldn't do any of the above.  I'd probably use a Lee Plug in a reamed hole.
But you haven't specified a working pressure, or a fluid, or a body material so far...
Mike Halloran
