Smart questions
Smart answers
Smart people
Member Login
Join Eng-Tips now!
Join Eng-Tips
LINK TO THIS FORUM!
Just copy and paste the
code below into your site.
Partner With Us!
Partner Button
(Download This Button Today!)
Feedback
"...love the site and am constantly recommending it to (selected !) clients here in ireland..."
Geography
bouk (Petroleum)
4 Nov 11 12:03
Hi everyone,
I have an existing control valve and I wish to check it is adequate for some different flowrates. When I model the valve in Hysys with a pressure drop, I notice that the liquid phase upstream of the valve becomes liquid with a bit of vapour downstream. Do I need to use any different equations to the liquid control valve sizing equation to determine my CV for these new given flowrates?
Has anyone a template I could use for checking?
casflo (Mechanical)
7 Nov 11 13:03
You must use different equations to obtain the maximum allowable  pressure drop in the valve to calculate the valve Cv.
For example if the fluid is water that at the valve inlet begins to flash, the maximum valve pressure drop used to calculate the valve Cv is: 0.04FL**2Ps(1+7(Ps/3206)**0.5
FL is the valve recovery factor. It depends of the valve type and manufacturer. A normal value could be 0.9
Ps is the saturation pressure in psia and the pressure drop is in psi.
If the valve inlet pressure is P1 and is grater than Ps, add to the former valve pressure drop the value (P1-Ps)FL**2 and if P1 is less than Ps you must subtruct (Ps-P1)FL**2
Regards.
casflo
Close Box
Join Eng-Tips® Today!
Join Us             Close
