Engine fan - delayed switch off
I have a pump and fan that run when the ignition is on.
I need them to continue for a few minutes (to avoid heat soak) when I switch off.
Basically I need to delay the relay switching off when the power is removed.
I thought it should be quite simple but I'm stumped - any ideas?
RE: Engine fan - delayed switch off
Dan - Owner
http://www.Hi-TecDesigns.com
I obviously wasn't cear in my original post, a turbo timer isn't quite what I'm looking for.
I don't need to keep the engine running, I just need to have a 12v supply to my electric pump and electric fan for a few minutes after switch off.
Something similar to the delay on an interior light when you shut the door - but for a few minutes not seconds.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
Bill
http://tinyurl.com/3c5epfl
