Placing 2D Spirals into a .DXF
I am trying to generate a .dxf file that shows multiple spirals using Solidworks 2007.  It seems I can only draw spirals by creating a new sketch for each one (since I can't create linear or circular patterns of them), and then, I can't seem to get the spirals to show up in a .dxf.  Any ideas on how to achieve this?  Any help is much appreciated.
Ken4242
RE: Placing 2D Spirals into a .DXF
After creating the spirals, convert them into a 3D sketch using the Convert Entities tool. Then re-try the DXF.
I can't get the Convert Entities option to become clickable when I highlight either the spiral or the sketch (the circle) on which it is based.  Any ideas?
Start a 3D sketch first, then use the Convert Entities tool.
I just did a quick test with SW2012, and I was able to save a DXF from the model directly from the spirals.
Same for SW2011.
Just realised you are still using SW2007, so maybe the DXF function was limited way back then. lol  Show your boss this thread and tell him/her not to be so cheap.
Hopefully the 3D sketch > Convert Entities will work for you.
Good idea about getting an upgrade!  :)  I open a new file, click 3D sketch, then draw a circle, then, when I go Insert --> Curve --> Helix/Spiral, I get a message that says "The sketch must contain only a circle."  Am I missing something obvious?
It turns out, the spiral was just defaulted to hidden when placed into the DWG file - I had to select "Show" to see it.  Still hoping there is a way to array spirals or create more than one per sketch, but at least I can make the DXF by brute force if needed.
Thanks again, CorBlimeyLimey.
OK, I may have been misleading you with the 3D Sketch. For some reason I had a tapered helix stuck in my head.
For the patterned 2D Spiral;
After creating the spiral, open a new 2D sketch and use the Convert Entities tool to propagate the spiral into the new sketch. That converted entity should now be pattern-able within the same sketch.
