Paralleling Transformers
What are the effects of operating two power transformers of different impedances in parallel?
When was the last time you drove down the highway without seeing a commercial truck hauling goods?
Download nowINTELLIGENT WORK FORUMS
RE: Paralleling Transformers
-nag400
Paralleling transformer seen to be a hot topic in this forum.
Please see the enclose threads that address similar question: Thread238-7093 Thread238-16427 Thread238-30275
A related topic could be the phase shifting transformer use to increase the power flow in a paralleling situation. The following thread has good reference Thread238-27103
A couple of added comments... If the transformers are not in close proximity, the system’s line-impedance characteristics will affect circulating current also.
It may be obvious, but circulating currents will present a highly reactive load to the source, and will exist regardless of loading.
please put your values (i.e. uk,Sn,S)in to
basic formulas given here under and calculate the loads shared by transformers.Then you will see the effects.
uk = S /((Sn1/uk1)+(Sn2/uk2)) [total imp.of parallel tr's.]
S1 = S*(Sn1/Sn)*(uk/uk1)
S2 = S*(Sn2/Sn)*(uk/uk1)
where;
Sn1;uk1 = rated power;imp.of TR1
Sn2;uk2 = rated power;imp.of TR2
S1,S2 = load shared by TR1,TR2
S = existing load fed by parallel transformers.
Sn = Sn1+Sn2
