Trimming Tubes
Trimming Tubes
Hey guys.
I'm CADing a space frame for a car and I am having trouble finding a good solution for trimming\extending the tubes to they meet in a nice way where I have nodes or 90degrees corners without radiuses. Would you suggest I use sweep, pad, rib, ... or what?
I am working from a wireframe with only points and lines.
RE: Trimming Tubes
As for the problem of tubes, I have used method where I extruded the profiles up to the bisecting plane in the nodes- in order to keep it tidy, if a little bit more 'complex', I used extrude, up to plane, (right click on field where plane is selected) create plane, through point and a line, select spaceframe node as a point and (right click on a field where line is selected) create line, as bisecting and then select centerlines of tubes joining in the node.
* but you must enable option 'keep link with selected object' in options (Tools>Options>Infrastructure>Part Infrastructure)
RE: Trimming Tubes
here is for solidworks, it's probably similar in catia
http://he
RE: Trimming Tubes
I was though afraid I had to make all these sketches and planes for every tube. It's so much faster to just sweep around line with a certain radius but then it might be tricky to get the right connections in the nodes, right?
Do you know if it's possible to use the same sketch for different extrusions in different angles etc?
RE: Trimming Tubes
RE: Trimming Tubes
As for multi tube nodes, up to a certain number of tubes, one can extrude up to surface of tubes that have already been placed (when prompted to choose surface, one can right click on the placeholder and create surface join to create one surface). At one point CATIA might refuse to create joints, so one extrudes to surface that can be created and then subtracts the rest of tubes*).
* of course, then one also have to remove lump that was left inside removed tube
RE: Trimming Tubes
