Custom Thread Length for High Strength Bolts
All,
Per AISC the thread length of a 3/4" A325 bolt is 1 3/8".
Several bolt manufacturers will customize thread lengths per the customers request.  Is there anything that prohibits the customization of thread length for high strength bolts?
RE: Custom Thread Length for High Strength Bolts
There is no restriction on thread length.  Fully threaded bolts are also available.  The primary issue would occur is X values are intended.
http://www.FerrellEngineering.com
You can make the bolt as short as you wish.  However, at some point you begin to get too few threads to carry the stress applied:  For example, you want a high strength bolt of a certain diameter to carry a calculated load.  If less load were to be carried, you could use a lower strength material or a smaller diameter bolt.
If you try to apply that predicted load through only two or three threads, you will strip those threads - regardless of what the AISC default length is.
