Section through part
Hello, I've seen many parts in the past sectioned like the one uploaded, but I can't seem to get Section View to do that.  When it takes out both planes I'm left with a quarter of the part, not 3/4 like I simulated.  What am I not doing right?  Thanks!
Mechanical Engineer
Field Forensics, Inc.
Engineering isn't about perfect solutions; it's about doing the best you can with limited resources. - Randy Pausch
RE: Section through part
guimba,
   My SW2011 cannot read your part.
   It sounds like you are trying to do a quarter section.  I do this by creating a quarter section configuration of the part, creating a quarter section sketch, and extruding it.  I attach it to my drawing.
   I have never actaully done this with a part.  I do it to assemblies so that I get clearer assembly drawings.
               JHG
Hmm, I see what you're saying.  Sounds like work.  Too bad I wouldn't be able to selectively section, like showing turbine blades within a cut housing.  Thanks for the idea.
Mechanical Engineer
You can selectively section.  Just do a Cut in an assembly and select the affected components.
Dan
www.eltronresearch.com
Dan's Blog
guimba,
   Actually, what I am doing is quite simple.  If I do my cutting at the assembly level, I can exclude the turbine blades from the cut.  The only labourious part is manually applying the crosshatches.
               JHG
Yep, that would work.  Thanks again for all the inputs.
Mechanical Engineer
