Solid Edge ST3 graphic issue - dimension value box won¦t respond
I´m having a problem with Solid Edge ST3 graphic. In dimension value box I can´t edit the dimension neither select dimension with cursor to change it.
Have already tried to reinstall the program and changed the program settings in Options but the issue remains.
SolidEdge(64-bit version) is installed on Dell M6500 with Quadro FX2800M graphics.
Does anyone have experienced the same kind of issue and what would help?
Henri
Henri
RE: Solid Edge ST3 graphic issue - dimension value box won¦t respond
Henri
