historical restoration
we have a historical restoration in process. the roof and and the two floors in the structure are shot-collapsing.
the walls appear solid and could be saved. we were wondering if anyone had any economical solutions for bracing/supporting the walls during demolition and reconstruction. we are concerned about collapse.
the building was built around 1880. the walls are about
15 inches thick and the foundation is solid.
RE: historical restoration
Then look at your final design solution. Can you introduce some masonry (or even concrete) piers which will not detract from the final job? If so these should be built next and will give you structural support as well as location points for temporary braces etc. You could also provide location points ("strong ponts") in such a 15 inch wall, once it has been re-pointed, for attachment of temporary braces. These can almost always be hidden afterwards (eg within depth of a new floor etc etc.)
Many more ideas but not the time. Hope this helps!!
ADT
prex
motori@xcalcs.com
XcalcS
Online tools for structural design
What we came up with was a series of vertical (temporary) trusses, tied to the existing brick walls which would be erected first. Then, interior floors and roof would be gutted one at a time until there would be a complete shell, open inside.
The new floors could then be installed from the bottom up with the new roof finishing off the work. I agree with ADT that re-pointing could be considered as a preliminary effort if it is determined that the wall condition required it.
As it turned out, doing this work was so expensive that the sisters told the historical society to go fly a kite (not their words) and demolished the entire building. We did replace it with a close replica of the original, though. The difference was about a million dollars US.
This bracing sistem is always made of steel elements. It is placed outside (of course) and must have very heavy foundations for its global stability. The connection between the bracing system and the masonry walls are usually made by wood plates - something like masonry sandwich - to spread the tensions that can appear, due to wind or instability.
Windows openings are usually used to connect the wood plates from both sides of the original wall, so that it wouldn't be necessary to damage it.
Finally, I think this system makes the demolition process safer.
Since then, buildings were made with a wood structure inside the mansonry, knowned by 'cage' buildings (that's the best translation I could find), wich brings flexibility to the all building.
I believe it was, eventually, at the time, the first effective anti-sismic construction technic.
Actually, the reason to maintain those ancient walls is only political.
If the contractors completely demolish a building, they eventually won't re-build it the same way. The City Hall prefers not having problems afterwards, with the harm allready done.
(Law procedures take many, many yars).
So, in that kind of buildins, the resistance of those mansonery wall is not considered, only its weight.
The resistance is assured by the structural concrete.
In fact we are talking about a completelly new concrete structure with some weights coupled, and not reinforced masonry walls.
It's much more expensive, but it's the price we have to pay.
Restorations are tricky and you need to assess the failures correctly. I would first work on the supporting elements. You need to render/plaster the walls straight away. Sika have a product called Sikacem810. It is a reactive bonding agent and mortar improver. You add that to the pointing/render/plaster. It will increase flexural-tensile & compressive strength of the wall. The additive also allows for the plaster's greater resistance to wear and abrassion that may result from demolition works.
Furthermore, I would allow for prop supports to slab at 1 metre from the walls. This will assist in ensuring that the floors do not shear on to the walls.
I believe that the 15" wall is of stone/rubble construction.
Hope this is useful.
Riz
