Viton sheet elongation % in X-Y plane......
Hi All,
Has anyone dealt with multi-plane elongation before?
I have a Viton sheet 1/32 thk that has an elongation % of 100. Thus I assume that a 1" long sample should be able to stretch to 2" long in the X direction before breaking.
I believe the std Elongation % test is only in one direction (X), but what happens when the sample is stretched in both the X and Y planes equally and simultaneously? It can't stretch to 2" x 2" right? Would it then be a function of the varying areas (e.g. Af/Ai = 2/1)?
All help greatly appreciated,
Quiz
Quiz
RE: Viton sheet elongation % in X-Y plane......
Will do....the more I think about it, something tells me it could be a funtion of area also. For the example I gave originally, if you stretch a 1 x 1 sheet in the X direction only 100% to a final length of 2 x 1 that is a 100% stretch and also a 100% increase in area. Does this make sense?
Quiz
That's Poisson's Ratio you're referring to. Yes, I'm aware of that but was mainly concerned with the ultimate tear point at max biaxial elongation in relation to changing areas.
Quiz
Rubber is a complicated material, and there is no easy way to predict its properties...see
http://ww
http:
A good friend and chemist/rubber expert once told me that molding rubber is like baking bread - you mix it, stick it in a mold and bake it, and hope it turns out like it did last time.
Think of a piece of string. If the two ends are pulled so the string is taught then the mid-point has a very limited range of possible movement. If the string is slack the mid-point is free to move over a much wider range.
