PVC foam constitutive description in ANSYS material model or USERMAT
Hello everyone,
This is my first post on this forum and I am really hoping that somebody can help me since I am more or less stuck.
Currently I am trying to define the mechanical behaviour, 2D in ANSYS, of a sandwich specimen in 3-point bending (E-glass facing and PVC core).
This particularly concerns the behaviour of the foam material when local indentation occurs.
The model (of the core material) that I am trying to use is based on the polymer foam constitutive model of Deshpande and Fleck. This model is based on the following:
tensile yield of the foam is governed by an elliptical yield surface in von Mises versus mean stress, while in compression the cell walls buckle elastically,
and a maximum principle stress criterion applies (buckling cap in the yield surface).
After studying all the possible non lineair material models in ANSYS I am starting to get convinced that this is impossible with the excisting models.
If this is correct it implies that I have to use the subroutine interface USERMAT.
The quetions:
- Is the assumption correct that there are no models available that can capture the mentioned constitutive model?
- Is it possible to use the usermat3D.F as a base for programming this constitutive model?
If anybody has some thoughts or experience please share.
Peter
ps. if some parts are not clear please let me know
