How do I link an NX6 Title Block Part Properties attribute to a Custom
I have my NX Title Block linked to Teamcenter using the few database attributes available.
<W@DB_PART_REV>
<W@DB_PART_NO>
<W@DB_PART_DESC>
The CAD administrator has added some Custom Teamcenter Attributes to Teamcenter including base material, plating, and heat treatment.
SHR_BASE_MATERIAL
SHR_PLATING
SHR_HEAT_TREATMENT
Is there a way to also link these attributes to our Title Block? I tried using the technique I found in these forums submitted by JohnRBaker about making a dummy part and linking the attributes to that part. This didn't work and I can only think that it is because of Teamcenter. See attached screenshot for more info.
