Springs..
Springs..
I'm trying to draw a sketch for the other end of this sprring I have here. To create the flat on the end to the right, I drew a sketch in the front plane, and made an extruded cut. After I did this, I made a revolve off of the face of the end of the spring, 180 degrees around.
Now I'm trying to do this on the opposite end of the spring, and I can't seem to get it. I drew the line in the center of the spring, which is on the top plane, to use as a reference and also to have that point down there to use as the center of my circle sketch. The line in the center about halfway is on the top plane as well, and was going to serve as a midpoint to mirror the sketch on the right end to the left end. That also did not work.
When I go to the left end of the spring and select front plane, it automatically draws the circle I'm trying to sketch in the top plane. I even tried rotating that gemoetry that was drawn in the top plane, to somehow morph it 90 degrees into the front plane, no dice..lol
How would I get this sketch down there so I can repeat the spring flat on that end??
Thanks.
[img]ht tp://i226. photobucke t.com/albu ms/dd198/J SMachine/s olidworks/ spring.jpg[/img]
Thanks.
[img]ht
RE: Springs..
Dan
www.eltronresearch.com
Dan's Blog
RE: Springs..
Now I am trying to get the revolve at 180 degrees to continue the flat.
RE: Springs..
TOP
CSWP, BSSE
www.engtran.com www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
RE: Springs..
SW Premium 2011
64 bit SP4.0
Intel Xenon X5650 @2.67GHz
2.66 GHz 11.9 GB of RAM
RE: Springs..
RE: Springs..
Dan
Dan's Blog
RE: Springs..
RE: Springs..
Check out what this guy does after he makes the extruded cut to create the flat. One more step to continue the flat around.
ht
RE: Springs..
I like to see the graphocal representation of the actual spring. I don't think my models are advanced enough yet for it to affect performance.
RE: Springs..
TOP
CSWP, BSSE
RE: Springs..
Dan
Dan's Blog
