Selecting a maximum value from a series of values
Hey guys.
I have a list of 6 different calculated values which can all vary depending on the inputs. From this point in the sheet the maximum value must be used with the others becoming redundant. How do I write in code to selesct the maximum value to use from there on out?
Cheers
Cheers
RE: Selecting a maximum value from a series of values
