Disconnectors
Disconnectors
Currently I am looking at replacement criteria for Disconnectors. Many people want the disconnectors replaced in their substation but I am not always sure why. For example, it seems that Hot Spots are usually caused by dirt - so why should a disconnector have to be replaced because of them? What are the common problems and faults you have experienced with disconnectors (I have heard it said they are the weak point in the substation) and under what circumstances should they be replaced.
Many Thanks in advance
RE: Disconnectors
As far as replacement, generally they aren't replaced unless the parts become difficult to obtain or the unit becomes a "problem child" that is costing more in maintenance and parts than replacement... Of course, if a substation is being rebuilt anyway then that may be a different issue.
RE: Disconnectors
Yes the maintenance and spare parts issue might be the reason for some specific models being requested for replacement. For example, does anyone have experience of a GE RB3 disconnector?
Does anyone know what lifespan can be achieved with disconnectors?
All comments much appreciated.
RE: Disconnectors
1)broken insulators
2)contacts not making well - eroded etc
3)hot spots
4)mechanism not functioning well
RE: Disconnectors
