cathodic protection
cathodic protection
do shunt resistors have to be installed in exd enclosures in a zone 2 area
RE: cathodic protection
Depending on what your CP system is protecting, you might want to look at BS EN 12954:2001 and BS EN 13636:2004 which are less prescriptive about the method of protection, essentially saying it should be in line with BS EN 60079. The old CP1021 is now withdrawn and BS 7361 (which replaced it) is largely superceded.
Life in the smog... I'm a missionary from a bit further north.
i will have to try and get info on what has been superceded in BS 7361,normally all of the kit ie,test posts,anode jbs etc are all installed in non hazardous areas ie for a petrol storage tank they would be installed outside of the bund wall,where i am they are not i think its a case of contractors cutting corners to make more money,thanks
