Offpipe software
Offpipe software
My Company has bougth an Offpipe (http://www.offpipe.com/) license and I found that it use a DOS interface. Anyone knows a software that can interface with Offpipe to avoid to use the Dos interface?
RE: Offpipe software
However, it is possible to prepare input files as .txt files using a word processor (Notepad as simplest one).
It will be more convenient if you use OFFPIPE interface in first place. Modify the input file text for detailed analysis or future use is then easy.
