ASME B31.3 - 341.4.3 Severe Cyclic Conditions
341.4.3 (c) "In-process examination in accordance with para. 344.7, supplemented by appropriate nondestructive examination, may be substituted for the examination required in (b) above on a weld-for-weld basis if specified in the engineering design or specifically authorized by the Inspector"
"May be substituted"
So, I can change item b (other examinations) to In-process Examination supplemented by NDT?
If authorized (...)
Weld-for-weld basis, what it means?
My English is not so good, sorry!
Thanks!
RE: ASME B31.3 - 341.4.3 Severe Cyclic Conditions
My take is that "weld for weld" means you cannot write your procedure to use 341.4.3.c on all welds -- you have to make a decision based on the particular weld.  I further read it to mean that the design engineer or the authorized inspector needs to agree with changing to In Process examination with appropriate NDE for a particular weld.
Patricia Lougheed
Please see FAQ731-376: Eng-Tips.com Forum Policies: Eng-Tips.com Forum Policies for tips on how to make the best use of the Eng-Tips Forums.
