Drop test at low temperature
Dear All,
I would like to study the drop behaviour of Polypropylene at -30oC from a height of 1.2 m. I have two questions in my mind:
Q 1: Is the Johnson/Cook model is the right choice for my kind of application? I have seen many people using this model in their publications. But my concern is that is it good model for Polypropylene as it is thermoplastics? I have checked the material models from Abacus and in their matreial data base they say it is good for metals only. I can see in this model that it takes into consideration effects of strain rate, temperature and hardening.
Q2: What kind of tests I have to perfrom to get material data for my model: tensile, compression etc and at what temperature these tests have to be conducted? Is it possible that I perform my test at room temperature and at a particular strain rate and then enter this data and my model will take into consideration the variation of temperature and strain rates based upon my boundary conditions etc. I reallly donot understand how it works?
I would be thankful if anyone could write me about my matter.
Thanks very much
Best Regards
Shahid
Thanks very much
Best Regards
Shahid
RE: Drop test at low temperature
H
www.tynevalleyplastics.co.uk
It seems to me you have confused a safe drinking limit with what I like to call "lunch"
