Using sed to create a directory
That thread was closed without an answer. Here is the key to what he was trying to do, not the whole solution.
Quote (jmarkus (Mechanical)):
25 Feb 04 14:52
I have a file: 12345-6789A.prt
I would like to create a directory: 12345-6789+A/
If I have 50 similarily named files (#####-####X.prt) I would like to create 50 directories.
I think I can use sed, for example:
for file in *;
do mkdir `echo $file | sed 's/'$1'/'$2'/g'` ;
done
where $1 is "12345-6789" and $2 is "12345-6789+", but I don't know how to make $1 and $2 be what I want.
Can someone help?
Jeff
Maybe this would help:
CODE
ls -X *.jpg | sed -r s/"^(.+)(\.jpg)"/"\1\/&"/
ls was used to get some meaningful input and sed's output was dumped to stdout just for testing. The idea for the regex came from Vladimir.
The rename command might do what the OP wanted more simply.
TOP
CSWP, BSSE
www.engtran.com  www.niswug.org
www.linkedin.com/in/engineeringtransport
Phenom IIx6 1100T = 8GB = FX1400 = XP64SP2 = SW2009SP3
"Node news is good news."
