corrosion rate of carbon steel
what is corrosion rate of carbon steel vessel where water flow slowly?
RE: corrosion rate of carbon steel
Impossible to answer because there is not enough information.
Information needed;
1. Water quality or type of water
2. Temperature
3. Flow rate
thank you Metengr
Is there any reference that get me corrosion rate of carbon steel in diffrent situation?
temperature:ambient temperaturere
conduct of water: 62
pH: 7.2
flow rate: 200 m3/h
Google the following: "Corrosion Survey Database - COR-SUR"
Steve Jones
http://www.linkedin.com/pub/8/83b/b04
Look in The Handbook of Corrosion Data from ASM, which reports corrosion rate test data from lots of sources under varying conditions.
Aaron Tanzer
www.lehightesting.com
