How to glue Pharmed tubing
I am trying to find a glue that would work well with Pharmed tubing.
Specifically to glue Pharmed tubing to a Silicon stopper.
I have tried Loctite and silicone glue. They do the job, but only to an extent. Pharmed is extremely chemical resistive, and seems to not bond with the glue.
RE: How to glue Pharmed tubing
Ultrasonic welding?
What exaqctly is pharmed tubing made of. Pharmed sounds like a performance based critera rather than aaterial type.
Silicons are thermoset I believe, so cannot be welded. Maybe the tubing can be riverted over with ultrasonics, depending on that the actual material is.
I take it both are elastomers which complicates adhesion as the glue has to move with the materials it is joining.
Pat
See FAQ731-376: Eng-Tips.com Forum Policies for tips on use of eng-tips by professional engineers &
http://eng-tips.com/market.cfm
for site rules
ergo 5861 cyanoacrylate will bond to PharMed apparently.  Not sure if it will bond to silicone.
@ patprimmer - That is my main issue as well; I don't know what PharMed tubing is made of exactly.
@ MintJulep - The silicone bits are being molded, and we have purchased the molding tool and everything. So changing that might be a long shot.
I will look into Ergo 5861.
